NHIrish
Aug 18, 2014Explorer
westend wrote:
Two things stand out to me from the pictures: First, that whole seam is holding water on the roof like a dam. Second, the caulking material is failing.
I would remove all of it and re caulk or use Eternabond tape, whatever is the choice of the OP. I've found that Eternabond tape is superior to any sealant I've used.
I would agree....am in the process of doing the same myself. I am using a metal putty knife with the corners ground off and it is working well. If you were to buy the 6" wide you probably wouldn't have to remove the old...also would use their spray cleaner.
44,068 PostsLatest Activity: Jun 21, 2026
