NCMODELA
Aug 18, 2014Explorer
djsamuel wrote:
In what areas should Eternabond be used and when should something like Dicor Self Leveling sealant be used? Or, can Etrnabond be used pretty much everywhere. My trailer has an aluminum roof, but Dicor is used along the perimter of the roof as well as around vents, etc. Is Eternabond an option along the perimeter?
djsmauel, I would be hesitant about using the eternabond tape on the aluminum siding along the uprights in the corners. I just tried that and it is a nightmare. Where the two siding peices slip into eachother it always leaves a gap and the tape will not fill that. It seemed to lift at every convex of the aluminum siding and took a ton of rubbing to get it to stay down and I'm not sure if it ever will fully, so that is why I have to caulk it now. Also the corner trim is less than 3/4 of an inch on the one side and the tape sticks out and you have to caulk over it. Unless someone else has a better idea and I am doing this wrong, it would have been easier with butyl tape and caulk. I have to recaulk it anyway. For the sides of the roof and top trim I would use it.
44,068 PostsLatest Activity: Jun 21, 2026
