Travelin2
Oct 22, 2017Explorer
azdryheat wrote:
No need to run max psi unless you want to beat up your trailer with a harsher ride and have uneven tire wear. Goodyear has a psi chart for your Endurance tires and they recommend 40 psi for a load of 1530 pounds per tire. You can find the chart HERE
Seems Goodyear isn't much concerned with sidewall flexing, heat build up, and such with these American made tires.
Well, The group as a whole voted for max pressure but azdryheat found some info from the guys that designed and tested these tires so I believe that's the smart route is follow the chart. The max pressure on the previous set of tires was 50# and that's what I ran. I think I will stay with that pressure for now as Ozlander suggested.
44,070 PostsLatest Activity: Aug 06, 2026
