mike-s
Oct 23, 2017Explorer II
JIMNLIN wrote:I can quote Goodyear, and provide a reference for the quote:
Goodyear says on the tires side wall "inflate to 65 psi". No questions about what Goodyear recommends.
Overinflating can reduce traction, braking ability and handling, as well as result in uneven wear and an uncomfortable ride...The proper air inflation for your tires depends on how much your fully loaded RV or trailer weighs...See load inflation charts...actual air pressure required should be determined based on the actual load on each individual tire.- Goodyear Tire Care Guide
Inflation pressure should be adjusted to handle the tire carrying the heaviest load, and all tires on the axle should be adjusted to this pressure.
