coolbreeze01
May 04, 2013Explorer
enblethen wrote:
Cold pressure temperature is somewhere around 80 degrees. You fill your tires to max 50 psi in this discussion and temperatures get over 100 degrees, tires will be well above max pressure. Bamb! No more tire.
In thousands of miles towing at max PSI, in over 100 degree temps, I never blew a tire. The slight rise in pressure due to temperature is a non-issue.
44,056 PostsLatest Activity: Nov 19, 2013
