The camper appears to be an LB model, meaning it is built for an 8' bed. If this is the case it won't work on you short bed truck. The camper would be in the 11' 6" range to 12' long. On your SB it would hang over the back by about 5' or more, not going to work. Also the COG (Center Of Gravity) would be way behind your rear axle.
You need to keep your eyes out for a camper built for a SB truck.
Also if you were to try and tow something behind with a SB truck you would need a hitch extension of over 5 more than likely 6'.
Also welcome to the forum. Lots of good info here just for the asking.
