theoldwizard1
Dec 05, 2016Explorer II
Artum Snowbird wrote:
My hot water heater had a heat linked fuse that sat in front of the thing. The connections to it were corroded, and that caused it to not work. While the idea of having a burner fire to cause the link to melt was perfectly fine if it shut off the propane valve, the wire to the fusible link failed at the connection.. and caused my strife.
My son-in-law and I carefully checked all connections with a 12V test light. Re-seating the switches did the trick.
44,068 PostsLatest Activity: Jun 17, 2026
