greenno
Jan 26, 2023Explorer
You do know that you have a regular fuse panel somewhere for your 12vdc feeds.
Those are just switches there is no overload or short circuit protection they just turn on/off those devices labeled.
Not sure what camper you have but it would be a good idea to familiarize yourself with the different systems in your rig. You know plumbing, electrical 12vdc, 120vac, mechanical etc.
Maybe your tank tender is fed from the same fuse that feeds your H2o pump.
I think you said your pump was struggling previous to them not working.
Maybe there's a reset button for the pump or probably you pop'ed the fuse.
Easy fix good luck.
Easy fix good luck.
