dewey02
Aug 15, 2016Explorer II
Here's a diagram of common water heater valve system.
I took this from a previous posting by our friend Roy Braddy.
If you have this system on your Trailer, the dealer likely closed the valves to the water heater (photo 2). Once you rinse the antifreeze out of your system, you need to open up the valves (photo 1) so water goes into your heater before you attempt to turn it on and heat water.
