Della330
Aug 15, 2016Explorer
brirene wrote:
Are you drinking from the water system? If not, I wouldn't bother worrying about sanitizing the system at this time until you're more familiar and confident!
We are not drinking from the taps - just brushing teeth, showering, washing dishes and toilet. So because we're not, I can just drain the antifreeze, push water in through the city water inlet til it runs clear, open the heater and fill it, and call it a day? Am I reading that right? Because that sounds way more do-able for this newbie!
In other news, I located a single hose protruding from the underbelly near the potable water tank, which I presumed to be the low drain. It's about a 1/2" flexible white hose with a valve on the end. But I opened it and nothing came out? Yikes. Help!
