poppin_fresh
Aug 15, 2016Explorer
I would also recommend that after you rinse the antifreeze out of the lines (and before un-bypassing the hot water tank) you sanitize them if you will use the water even just for brushing your teeth.
I dont get too scientific about it, but I just disconnect the fresh water hose and pour about a quarter to half a cup of bleach into the hose. I then open each tap a little until you smell the bleach. Let it sit for an hour or so and then open the taps to flush it out.
