Della330
Aug 15, 2016Explorer
poppin_fresh wrote:
The hose you found drains the fresh water tank. Nothing came out probably because the fresh tank is empty. No worries.
The regular low point drains are typically Red and Blue and next to each other somewhere else.
There are two little hoses that come out of the underbelly sheeting at this spot, just in front of the tire area. One is sealed/capped, and the other has this black plastic valve on the end. I don't understand. The lines inside, under the bathroom sink which sits just behind the tires, those hoses are red and blue.
Dense question - how did the dealership winterize it if the tank is empty?
