brirene
Aug 16, 2016Explorer
Della330 wrote:
So how did the dealership get the pink antifreeze into the plumbing lines if they didn't put it in through the fresh holding tank?
A winterizing kit, which you probably have on your system. If you do, near the pump you'll have a "T" in the line. One line goes down, into the fresh water tank, the other is a short line that just seems to be there, going nowhere. These will be on the intake side of the pump. Each should have a valve. When you close the one going to the tank, and open the other, when you turn on the pump you'll be able to draw antifreeze directly from the bottle when you winterize. Should only take a few gallons to do it. None in the tank. If you don't have the kit, you can add one, purchased or homemade. But that's something you don't have to deal with till you winterize.
