coolmom42
Aug 22, 2016Explorer II
poppin_fresh wrote:
I would also recommend that after you rinse the antifreeze out of the lines (and before un-bypassing the hot water tank) you sanitize them if you will use the water even just for brushing your teeth.
I dont get too scientific about it, but I just disconnect the fresh water hose and pour about a quarter to half a cup of bleach into the hose. I then open each tap a little until you smell the bleach. Let it sit for an hour or so and then open the taps to flush it out.
Absolutely! If you are using the water at all, you need to sanitize the lines.
