chracatoa's avatar
chracatoa
Need to hire welder - help!
So I need to do some spot/tack welding on my hitch. Any ideas where/how can I find these kind of professionals that do the job - and for a reasonable price?
I found just one - minimum quote is $400, seems too expensive.
A friend of mine told me we could take a class together. I'm all for learning new things but I'll be driving this thing and I don't want to do a bad job. I know nothing of welding. Would you do it?
Thanks!
  • Or, get some all-thread rod and washers and nuts to fit. Bend the all-thread into a "u" bolt configuration that will wrap over the top of the frame and bolt the stabilizers on the bottom of the frame. No welding, no holes drilled in the frame.
  • beemerphile1 wrote:
    westend wrote:
    Look in the Yellow pages for welding services...
    My thoughts exactly. I have several local welding shops I have used over the years. If I looked in the Yellow Pages I bet there are 30 or more welding shops in my area.
    Attaching 2 jacks shouldn't be more than an hour. Around here a quality welder will cost you $75 for an hour job.
    If I travel 10 miles out West into the first small town, I bet it would be a $25 job. :B
    Recently, I had a small town machine shop remove and press new hubs and cartridge bearings into a steering knuckle. It was done in 30 minutes and the shop charged me $21. For a sawbuck, I'm not getting my hands dirty, lol.
    Good advice on disconnecting the electrical. A guy might want to remove the AC ground, as well.
    FWIW, I'm still collecting scissor jacks as I see them at garage sales. So far, I have three that have the same end on the threaded rod. Looking for the fourth.
  • Just screw them on with the included hardware, if they came with it. Most are done that way. Besides, it'll be easier to replace if it gets messed up by a rock, curb, driveway, mother-in-law, whatever.
  • If I were doing it, I would bolt the jacks to the frame, and I wouldn't be concerned about weakening the frame. However, if you are set on having them welded on, here is a guy that has done good welding work for my trailer. I think he charges $75 per hour:
    Fall City Welding
    33623 SE 43rd St
    Fall City, WA
    (425) 222-5105
  • We've had a mobile welder guy come out to our place a few times for some misc. small stuff. Pretty inexpensive..... Listed in the yellow pages. You may find them on Craigslist too.
    On the holes in the frame question, what about all the holes made from self-tapping screws for the underbelly material?
