Larry-D
Mar 16, 2018Explorer II
Replaced ours last weekend. Lowes with a higher arch and single handle. Fit perfectly, standard 4" spacing between the holes in the sink. The PEX lines worked with a little manipulation of the copper lines coming out of the faucet. The fittings were also the same. 15 minute job. You may not been a faucet wrench. Was able to easily reach the faucet and connections were hand tight. The new faucet used large washers and a nut to tighten down. Did need a ratchet, short extension and a deep socket.
44,068 PostsLatest Activity: Apr 17, 2021
