TucsonJim's avatar
TucsonJim
Explorer II
Mar 17, 2017
Need To Tint Skylight
Have any of you ever tinted the interior portion of a skylight? I have two skylights in my current rig and they are letting in too much heat and light.
I don't want to use blinds, curtains or anything that blocks them. I just need to darken them up. Do any of you have experience with this type of project that you could share?
Jim
  • it would be easier to just get some of those padded fillers made to stuff in the opening.
    bumpy
  • I installed vinyl siding J channel on three sides and just slide in a piece of foil faced bubble wrap into the channel, it has an R value which helps block out the heat and can be removed when I want light.
  • Big Love wrote:
    I did both...painted the outside dome with white Krylon paint (hopefully sealing some spider web cracks forming after 7 years in the sun) and put stick on window tinting on the inside bottom panel. Nice and shaded inside now, but still an adequate amount of translucent light in the shower.
    I was going to mention Krylon myself, and I see they have a couple of new and "improved" stuff.
    bumpy
  • I did both...painted the outside dome with white Krylon paint (hopefully sealing some spider web cracks forming after 7 years in the sun) and put stick on window tinting on the inside bottom panel. Nice and shaded inside now, but still an adequate amount of translucent light in the shower.
  • Jay Pat wrote:
    I lightly, spray painted the outside part with white fusion krylon spray paint.
    I decided to give another light coat.
    Seems to work well for cutting down brightness inside rv.
    I think it has cut down the heat transfer. No test for comparison.
    Pat
    X2..Gives a nice soft light and did seem to cut heat transfer down some. Did the one over our shower.
  • I lightly, spray painted the outside part with white fusion krylon spray paint.
    Pat
  • Take the interior one down and sand which a piece of astrofoil between them it blocks out the sun and insulates
