Since you're going to be using the trailer over the winter then draining and blowing out the lines will be the quickest way to winterize / de-winterize. There's no need to flush out the pink stuff out of the lines which saves time. Our hard freezes generally don't last very long and we don't get them often so blowing out the line should be good enough for down here. Just remember to get the outside connections like the outdoor shower and outdoor kitchen if you have them. Don't forget to put some antifreeze in the traps and drop some in the holding tanks just for good measure.
