Dave_Pete
Jan 23, 2015Explorer II
Need Your Screw Method Advice - 1968 Travel Queen Resto Mod
Okay so here's the dilemma. I hope to do this job soon so need your thoughts soon.
Should I go with screw fastener method 1 or 2? The areas to join are the wall segments, into the floor segments.
Front wall...
Back wall three sections...
Method 1 - Countersink a hole from below and pre-drill pilot hole for about one inch of screw bite upward through part of a 2x2, through 1/2" fiberboard, through 1/2" of plywood, into edge of 3/4" plywood.
Screw head and hole...
Pencil mark indicates the screw placement...
Method 2 - Pocket screw from above, through about 1/2" of remaining unremoved plywood edge, through 1/2" plywood, through 1/2" firberboard and into 2x2 with again, about 1" plus of screw bite.
Screw heads and holes...
Pencil mark shows screw placements...
Method 1 leaves more of the plywood wall intact - less destruction. What do you all think?
Front wall...
