skiproExplorerAug 14, 2017Negative TVWe have a 13 inch, RCA TV in the trailer. Whenever we use it, whether on OTA or cable, the picture looks like an old negative photo. You have to stand in just the right place to see it properly. Su...Show More
DiskDoctrExplorerAug 14, 2017Check your connections. Are you using cable (F-type), RGBY, HDMI, 75-ohm?If you have strands of cable messed up or missing, or not-quite-connected connectors, you can have this problem.If it is an LCD, you could have your backlight damaged on the screen.We really need some more info about your TV and connections to help more ;)
Related ContentNegative and ground wire questionsnegativityNegative/Ground wireNegative dew points in AZMobile Repair - Positive or Negative?
