lenr's avatar
lenr
Explorer III
May 15, 2019
Negative/Ground wire
Our first trailer had both the positive and negative 12 volt wires running from the battery to the combination distribution/converter panel. The negative wire was also grounded to the frame. On the next two trailers, there was no negative wire. Negative was grounded to the frame at the converter and at the batteries with a fairly small self-tapping hex head screw. My concern is long term corrosion at the frame grounding point. 1) Am I being overly concerned? 2) Is there anything wrong with adding a negative wire, but leaving the frame connections? It seems to me that the wire will increase the odds of a good solid connection for years to come.
