NRALIFR wrote:
No state weight station cares how much I weigh.
Why? Because I’m not engaged in commerce.
More likely they don't care what you weigh because you are not likely to be near the legal limit.
In my state, if a CMV LEO sees you obviously over your registered weight limit, they can and will stop, weigh, and ticket you. (Once, standing in line to pay my overload ticket, the 3 in front of me where pulling boats behind half-ton pickups with 6,000 lbs. plates.
The only other legal thing a RV is likely to be over would be tire rating. To catch that at a scale house, first, he would need to note weight on the axle, then look at sidewall. Then he would need to weigh just that tire. Then, in my state, the fine for overload is $0.02 a pound for the first 500 lbs, and $0.05 for the next 500. (Even on CMVs normally don't write unless 1000 over) Also, if they weighed a RV, noted it was overloaded, then let it go there could be liability issues.
Trackrig wrote:
If I'm wrong, they can send someone after me.
Bill
You do you. If I'm in doubt, I will pull in. If they don't want me, all they will do is tell me to leave. OTOH, if they do want me, and run me down, not only do I have the fine for running scales, the LEOs will be more ambitious to find what I want to hide
