leftybj
Jun 08, 2014Explorer
First and foremost, THANK YOU FOR YOUR SERVICE TO YOUR COUNTRY!!!!!
Now, I have set up in campgrounds where the 30 amp socket is old, loose, worn, and sometimes look like they have been really hot at some point. If this is the case I use a 50 to 30 adapter as those sockets are usually in better shape. I am not saying this will cure your problem but it is one thing that can cause excessive heat at the plugin. Might as well eliminate that one.
Good Luck.
Good Luck.
44,071 PostsLatest Activity: Aug 30, 2026
