Lowsuv
Jun 08, 2014Explorer
Most electrical fires are created at the POOR connection .
When the male and female connectors do night fit perfectly tight heat will occur .
Hence the usage of "twistlock " type connectors for industrial usage .
The remedy of getting a 50 amp to 30 amp adapter is a good solution .
The 50 amp receptacles at the rv parks are generally less worn .
So you should have a good 50 amp connection to your adapter and a good 30 amp conection from your adapter the the male end connector of your rv cable .
44,071 PostsLatest Activity: Aug 30, 2026
