billtex wrote:
Bedlam wrote:
The prewired setup may be able to be used to attach additional batteries. The generator starter lines are typically heavy enough to use as a link between batteries. If you do not already have an external LPG connector for an outside grill, the line in the compartment can be used for outdoor cooking.
That's what I did with our previous Adventurer...easy way to add 2nd battery.
Did you do anything to strengthen/support the floor before adding battery weight?
I guess it was designed to support a generator so it should support batteries!
