PointTaken
Dec 27, 2016Explorer
@ work2much Those heaters being quiet is another advantage I had not thought about. I did notice I had less power than anticipated.
@Buzzcut1 Great tips on making insulation for around the windows and doors. I cut foam for the vents and skylights but did not consider adding foam to the windows and door. Are you using the 1" foam and reflectix at the door and window or just the reflectix? I used the factor shades and noticed a difference, I bet your method really helps!
@deltabravo That is a good point. Maybe just open the door a few minutes prior to showering. I don'd mind Navy showers just was surprised how little insulation the wet bath has.
44,058 PostsLatest Activity: Mar 16, 2026
