Buzzcut1
Dec 28, 2016Nomad II
PointTaken wrote:
@Buzzcut1 Great tips on making insulation for around the windows and doors. I cut foam for the vents and skylights but did not consider adding foam to the windows and door. Are you using the 1" foam and reflectix at the door and window or just the reflectix? I used the factor shades and noticed a difference, I bet your method really helps!
the door glass has foam and the entire door, except for the latch, has refletix covering everything
44,058 PostsLatest Activity: Mar 16, 2026
