Buzzcut1
Dec 30, 2016Nomad II
Bryan is correct about the tank valve compartment. When I started my insulation project I was shocked at all the air gaps I found. There was a direct path from the valve comparment to under the shower pan and then into the sub floor area of my Lannce 1055 I used metallic tape (others used expandable foam to seal the air gaps) and then I packed the valve compartment with Fiberglass batts. It made a dramatic difference in inside temperatures. I also have to storage compartments that have both external hatches and inside the living space access doors, under the dinette seats. again the use of fiberglass batts and weather stripping made a huge difference.
44,058 PostsLatest Activity: Mar 16, 2026
