ksg5000
Feb 03, 2016Explorer II
Check the battery voltage when plugged in - s/b around 13.6. If your voltage is low then my next step would be to check for an "auto reset circuit breaker" near the battery -- they don't look like a std breaker - here's a pic.
http://www.amazon.com/gp/product/B001PTBVL2/ref=pd_lpo_sbs_dp_ss_2/188-3688398-7039616?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=lpo-top-stripe-1&pf_rd_r=0N0ZEMWV9Y1SRFSMZYA5&pf_rd_t=201&pf_rd_p=1944687722&pf_rd_i=B0021W0HFI
If that breaker doesn't have continuity between the polls - it's bad. If the breaker is OK then you should check the fuses on the converter - if they are Ok then your converter probably needs replacing.
44,068 PostsLatest Activity: Jun 21, 2026
