hohenwald48
Feb 04, 2016Explorer
I'm not sure he'll read above 13.5VDC if his battery is totally discharged. Even if his converter is working just fine.
To check the converter fuses you will have to get access to the converter. The fuses should be visible. The converter is likely under a cabinet somewhere. Usually have to remove a panel to get to it.
44,068 PostsLatest Activity: Jun 21, 2026
