jimh406
Jun 11, 2018Explorer III
Assuming the trailer weighs around 700 lbs, you are looking at a 2000 lb tow. It's possible to use the extension, but make it as short as you can. 18 inches would be better. You are going to be weight challenged once you add the tongue weight no matter if you have a Superhitch or not. That would probably be your more pressing issue.
Here's another related thread on extensions. https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29661175.cfm
44,056 PostsLatest Activity: May 04, 2014
