oneluv1979's avatar
oneluv1979
New Camper New Problems Septic and Drain issues Please help!
OK i just brought home today a new to us 2008 Keystone Cougar X-Lite and i found a few issues...Please help me out i am lost....
1) The water tank drain is missing a cap but its a odd cap and i am lost on finding it.... Here is a picture...
2) The black and gray water run off look connected to each other the off thing is the valve is way up under the camper... Never seen anything like this before and there is no valve for gray water...
Again look at the pic....
  • Actually the the cap you need for the fresh water is Flair-it cap cap. Probably 1/2 inch. The fitting is made by Flair-it and pex slipsover the end with the proper Flair-it nut to tighten the pex to the fitting. The Flair-it cap is used when the tubing and nut are removed or not used. The shape of the inside of the cap is made to seal against the barb on the fitting.
  • Mobilefleet gives a good run down on the issue. I would go back to the dealer immediately and show them the issues. They should provide a fully functional TT and fix any issues that exist. If the dealer knew issues exist and did not point them out, they are less than fully reputable. Any good RV shop should be able to look at your unit and offer advice on what needs to be done. Best wishes and I pray you get to camp soon and that the Good Lord gives you many fun and safe trips.
  • the cap for the drain is available at any rv parts store. Tell them you need a pex cap for the fresh water drain. The valve for grey/black looks like someone has previously been monkeying around under there. That mesh looking stuff isn't stock to the trailer and valves should be accessible outside of the underbelly material. It could be a drain release for a second grey water tank if you have one. Some campers have a separate galley tank, which should show on your tank monitor inside. If so then the other drain valves are located further down from there under the camper
