time2roll
Mar 23, 2017Nomad
DiskDoctr wrote:Give it a go if you like. If working properly to charge low batteries you should see voltage steadily climb above 14.2 volts and hold for four hours. Good luck.
According to this specs page, it is already a 3-stage charger. Maybe I do not have to replace it?
WF-8955 specs page
When you realize the WFCO is a fail I recommend this one: PD9260-14.8
The PD4655 is fine also at 14.4 volts if you are worried about the LEDs. Although most good ones I see are good from about 9 to 30 volts.
IOTA is also an excellent converter.
I would stay away from Boondocker. While it always starts in boost mode, boondocker cuts down to normal mode too soon. Depending on rating, wire connection, and battery boondocker drops voltage at about 75 percent charged. Then it is just a trickle to 90+ percent.
