horton333
Mar 23, 2017Explorer
time2roll wrote:
OK that is the first post I have read where Boondocker holds boost more than a few minutes after reaching the set point of 14.6 volts. This is the BD1245, BD1255, and BD1275 main board replacement not the deck mount converters. If it holds 14.6 volts for four hours on the battery then it will work well. Many posts on the deck mount dropping out early and virtually no literature to confirm either way.
I've no direct experience on the deck mount one to comment. Tech support there are quick to reply and seemed competent. Have they been contacted?
For something designed specifically for Boondocking that would be a significant design flaw.
I was just reviewing the information I was sent. It does make a note that it can drop out in only 15 minutes if the battery is determined to be charged. I wonder if it is possible for it to get fooled and I have just not seen it, I assume it was dropping out on people who had batteries that needed full voltage?
