DiskDoctr
Mar 23, 2017Explorer
DiskDoctr wrote:
I'll look into the 60 or 70 amp PD. I think 80 is larger from the pics
According to the pics and listed dimensions, the 80 amp is 3 inches longer and just under 2 lbs heavier and $28.
Input: 105-130 VAC, 1300 Watts
Output: 13.6 VDC, 80 Amps
Dimensions: 3.6" X 11.5 X 9
Weight: 7.5 lbs.
Any reason NOT to go with the 80 amp? On battery power, will it run hotter, use more 12v, or anything else?
I'd really appreciate an opinion on PD 9280C 80 Amp RV Converter/Charger, found at Best Converter
Progressive Dynamics is pretty much top of the line, right?
