DiskDoctr
Mar 24, 2017Explorer
afidel wrote:
Hmm, at 25' I think I'd go with a deck mount charger, even if you put in 14.8V and used massive 1AWG cable you'd still only be putting 14.3V into the battery which is barely enough to really charge it at a decent pace. That's the one drawback of low voltage DC, distance kills your efficiency.
Deck mounted...as in MOVE the charger/converter, or use a separate one?
Doesn't the charger also supply 12V to the coach?
So I'd have potential voltage loss going back to the circuit panel, but likely never use the number of amps the battery charging would, right?
