gmcsmoke wrote:
jus2shy wrote:
ksss wrote:
jus2shy wrote:
ksss wrote:
Redsky wrote:
Something that is very different with diesels is the rate of change with the manufacturers coming out with new versions which fix problems with prior year models but introduce new flaws. Gas V-8 engines can be sold for decades with minor changes (post unleaded gas) but GM for example has had 5 different engine designs in the past 10 years.
Really? Care to elaborate on the 5 different engine designs of the Duramax?
LB7 - The Original
LLY - Known for overheating, but had VG Turbo
LBZ - Fixed overheating, most reliable known
LMM - 2007 emissions compliance
LML - 2010 emissions compliance (DEF)
You consider these to be separate engine designs?  The basic design of the Duramax has not changed since inception.
It is true that certain items can be retrofitted, but they all have slightly different architectures. It's almost as simple as the chevy LS small block. It's been the same basic motor for the better part of 10 years, but each generation where GM designates a new code has quite a few improvements and changes (even though they're difficult to tell). Here's a good webpage showing the design changes through the generations: Diesel Power Magazine
Wikipedia has a nice breakdown as well: Wiki
lol you're clueless
using you're logic cummins has three different engines available in 2013
Nope, mechanically speaking the three Cummins motors ratings are mechanically identical. All that truly differs is the ecu setting. Also, to call one clueless and insult them does not add to the conversation but only serves to boost one's own ego. Also, it is gm that differentiated the identification of the engine. I'll agree that some of the tweaks are minor between the generations, but the lbz was the real changer with some large mechanical changes. I'll be honest and say I don't know how much is interchangeable between the blocks, but they are identified as such. Cummins does make many versions of the isb as well with different cm versions. The ram/Cummins forum trend to identify their engines by the major changes such as 12 to 24 valve, or injection system from vp44 to common rail. Otherwise, by your logic, Cummins will have only made 2 motors since the 80's for dodge/ram. Hell, the 6.7 still uses a lot of the same parts add the 5.9. Is that a change? Or how about all the 5.9 motors from 89 to 2007?
