Dandy_Dan's avatar
Dandy_Dan
New Dodge Ram Pickup
Saw one of the new Rams today at a new car show. I can't figure out how anyone is going to to a 5er and have any bed clearance. I have a 5er we tow with a 2005 Dodge, having about 5" bed clearance. Our bed is 54" from the ground to the top of the bed rail and trailer sets level. The new Ram has a bed rail height of 60". How are you to tow level without having to put suspension blocks under the 5er? Our 5er is running on 16" rubber. Kind of eliminates the new Dodge doesn't it?
  • Well, I just hope the new 3500 DRW air spring setup does not try to maintain the ride height as it sets without a load, or 5th wheel towing will be a real issue. Saw a video of the 2500's air suspension and it tries to maintain height!
    The 2500 will have a complete air setup and the 3500 a single leaf spring and air bags.
    Chris
  • I have a 2014 Ram 3500 with the 5th wheel prep pkg and a Reese 21k hitch mounted on the picture frame adaptor. My 2013 Raptor hitches up with 6 1/8 inches of clearance.
  • 45Ricochet wrote:
    We have a member here who's RAM 2013 dually is 58.5" but what's a inch and a half between men :B My 2006 is 58" unloaded and with a little hitch adjustment I have 5.5" of clearance. It does squat a good 4" hitch up though.
    Got news for you, go measure all three and let us know the results, I'm sure they are all in the same ballpark, give or take a inch and a half or so :W
    That's the second time you've remembered that for me Rick:B Yep, my 2013, tailgate height, with the plastic protector on top of it is 58.5" high....I have the GN/5er prep package and the picture frame adapter, which sets higher than the rails one would normally use in conventional 5er hitch install....I DROPPED my hitch one notch to compensate for the height of the adapter...I don't have 6" of clearance, more like 5.5" of clearance, but 5er sets closer to level with this truck than it did with my 05 Chevy 3500 cc/lb dually, then the 2010 Dodge 3500 cc/lb dually and the 2012 Ram3500 cc/lb dually. I have a semi-steep driveway that I back into, no issues, I have to negotiate a steep curve just about 100 yards from my camp in WV, coming out, still had about 1.5" of clearance.
    I agree though with OP, trucks keep getting taller (higher)...but, as far as towing a 5er, I've towed the same 5er with 3 different trucks and this one set's the "most level" of any of them and it's the highest.
    I've done nothing else but to lower my hitch one notch, several other things one can do.In reality, Chevy, Ford and Ram have all gotten taller, (not just Ram), but it's not that big of a deal to tow with them, just takes a little research....as stated above, sure do see a lot of these brand new trucks out on the road towing 5er's and they look fine.
  • Dodge no longer makes Ram and has been that way since 09.
    But to the question, there are lots of posts on bed height on all the truck manufacturers. People are still towing with them.
  • this isn't truck manufacturer's fault this is on the RV industry. for years and years they've made bigger and heavier f'vers and don't upgrade the ride height. Truck manufacturers have to fall suit with stronger frames and tires which in turn raises box heights.
    it's about time trailer companies put 17 -18" tires on their trailers.
  • We have a member here who's RAM 2013 dually is 58.5" but what's a inch and a half between men :B My 2006 is 58" unloaded and with a little hitch adjustment I have 5.5" of clearance. It does squat a good 4" hitch up though.
