Nautique200
Aug 25, 2015Explorer
New Eagle Cap 1200
I was checking out my local dealers inventory of Eagle Cap 1160 and 1165s and stumbled across a 1200 listed. This must be a new model that Eagle Cap is about to launch.
New EC 1200
New EC 1200
kerry4951 wrote:
Im not sure if they are the same company, but the track slide out mechanisms that mount under the slide outs can be stopped at any point, partially or fully extended. As far as Im concerned they are much more time tested, proven, and dependable from the feedback that I have been seeing.
805gregg wrote:Nice-let's see a picture of you with your camper.
A lack of headroom is a problem with every Eagle Cap camper.
Eagle Caps only have 78 or 76 inches. Subtract 2 inches for the AC equals only 6' 2"or 6' 4" anything taller equals ducking or lumps on the noggin.
California King sized beds in campers with low headroom seems such a waste.
Although this tall person has about given up all RV's. Not enough headroom or not enough bed room. Rats!
We have a California King in our home. How many normal sized people even know what a California King is?
( a 6 foot by 7 foot bed
What is the headroom in your TC?
Looks like an ant under an tortoise shell wow that is way too big, my Lance camper has 6'10" of headroom
billtex wrote:
Can someone clarify;
Lippert (Happijac) slides are underneath (floor slide).
Schwintek are on the side (wall)?
Is the Lippert mechanism also to be used only fully extended/contracted?.
Or can it be used partially extended?
Aren't they both the same company now?
Thanks.
Thanks.
Fastbrit wrote:Butch50 wrote:
Also now that Eagle Cap is using the Schwintek slideout for their campers. The old saying about if you need to use the bathroom and the slides are in the way just put them out a little. You can't do this with a Schwintek slide. Once you start putting it out you are supposed to extend it al the way and hold the button for a few seconds after it stops. I know this as this is the same slides we have in our MH. The only difference is I can use ours with the side in or out.
If you stop the slide part way out the 2 motors can get out of sync and you have to go through a procedure trying to get them synced up again.
We have the Schwintek slides out on our camper and never had any sync problem when we stop them part way out
