Also now that Eagle Cap is using the Schwintek slideout for their campers. The old saying about if you need to use the bathroom and the slides are in the way just put them out a little. You can't do this with a Schwintek slide. Once you start putting it out you are supposed to extend it al the way and hold the button for a few seconds after it stops. I know this as this is the same slides we have in our MH. The only difference is I can use ours with the side in or out.
If you stop the slide part way out the 2 motors can get out of sync and you have to go through a procedure trying to get them synced up again.
