shelbyfv
Dec 22, 2018Explorer
Kevin, thanks for posting your door stickers. That HDPP gives you probably close to 1000lbs above the average F150, well worth a search! It's encouraging to see that they are actually available other than special order. Also interesting to see what Ford recommends for pressure with the E rated tires. Some of us have upgraded to E from the OEM P rated and there is discussion about what pressure to run. 55 is about what I decided on using the tire mfg load tables, so good to have some confirmation.
