VernDiesel
Dec 24, 2018Explorer
I’ve properly set up to scale results both PP and other WDH with built in sway control. If you don’t swap trucks & trailers often they are an expensive but good option and they are in many respects “the best”. That said mich800’s post was spot on. Any property sized WDH with built in sway control will work fine if you take the time to get your tongue & axle weights right. Any hitch including PP & HA should especially at the rated limits of your truck be set up by scale results. It’s the only way to know & insure safe stable results.
