demiles
Jan 03, 2019Explorer
Groover wrote:
I just can't figure out why the max payload package reduces the GCWR so that if you get the axle for the extra tongue weight you are not rated to pull as much trailer.
The reason is because of the higher GVWR. The SAE standard has a section that requires the test vehicle be loaded to RAWR, GVWR, and GCWR at the same time. For this truck under these guidelines the higher GVWR becomes a handicap and lowers the GCWR and TWR.
