pjay9
Aug 15, 2014Explorer
New Fresh Water Pump
Well I had a Shruflo 4900-0211 constant flow no matter the tap opening. It worked very well for 3 years then started having issues. The adjustment screw always seemed to help. Well it stopped after getting very hot, so hot I could not touch it. After it cooled off it would not run.
So ordered a new pump as I had read that the old sytle (mine) is having issues. The new pump swapped in nicely only needed to extend my pos(+) lead. It comes with a strainer and is required and the proper quick screw on connectors. If I rememeber correctly the old pump I needed to buy strainer and some fittings.
It seems to work differently than the old one. It pulses when the tap is opened to a trickle but no apparent change of flow or pressure. That pulse noise is annoying right now and probably will not be after I get used to it. The old one ran slower at trickle and that I think may be some of its ultimate down fall.
The new one has some very detailed adjustment schemes for varing the pressure...I am not going to mess with that as it seems to be a good flow and usable.
Now for an explanation of my DOWNFALL comment. I took the old one apart and found the rubber bits dirty and covered with a thin furry looking stuff. I found that a couple of screws in the water chambers had rusted even so they were SS. I found a pressure diaphram that appears to leak, which could have been the reason the pump never shut off and heated up as it was always running slow. The motor would run but very bad or not at all when hooked up to 12v. It wanted to but justed didn't have the go. Popped open the case and pulled armature, the brushes were looking good but the surface they rubbed was black...emery cloth and shiney again...reassembled and 12v hook up away it went! So should I have just opted for a rebuild kit for the rubber bits...NO...because the new one has sorted out the overheat issue by not letting it run slow and it is the next generation of these type of pumps...which can't be bad.
Do I get a rebuild kit and have old pump on hand as back up...MAYBE!!!
YES, a bit spendy, but I don't have the issue of an accum tank , more fittings to leak and pulsating...which is a real good thing when showering. I do have to say that the old pump really didn't owe me a thing...the use was constant every summer everyday when I lived at the dock in Seattle, on many trips lasting 3 to 10 weeks, and all the year round short trips...I don't begrudge it finally giving up.
Do I reccomend these constant flow no pressure change pumps WHOLE HEARTEDLY!!!
New one is a Shurflow 4048-153-E75 4 GPM RV High Flow Fresh Water Pump.
BTW, I turned on all the taps, galley, head sink, shower and then flushed the head...saw no appreciable change...WORKS for me!!!!
