Small update on stove. The top is one that you push away from you and lift up at the same time. All I had to do is install 4 screws into the edge of the counter top. On the bottom I did pre drill some holes in face frame before I installed screws because I don't no what kind of wood it is and I was afraid to crack it. Very easy fix. I think all the plumbing is next. So far all I have done with that is get the draws out and some plywood so I can get to everything. While I'm at it the wiring looks like it could use some attention. I have Pex tools for 1/2 and 3/4 I will half to check and see what size because Id like to install a toilet shut off valve sometime and will bring some spare Pex and fittings with me this spring. Thanks for the heads up guys.
