gmw_photos
Oct 24, 2013Explorer
Txfirerescue77 wrote:
My current wheel width is 15x5 and I have some wiggle room but not a ton, I was thinking about a 215 70 15 in D load range. Everybody talks about cheap trailer tires and blowouts galore that it makes buying, what should be a relatively simple purchase, a royal pain of research. I want something that will hold up as everybody else does, but I
Can't afford to brake the bank in the process. Looking at the maxxis it has good and bad reviews like all the rest do. I do have to ask, are all the blowout stories due to faulty tires or more along the line of improper care, such as too low of air pressure, too infrequent of use, and so on?
you're sure that is a 5" rim ? That's pretty narrow.
EDIT: I just did a little checking, and I see that some 15" steel wheels are in fact 5" wide. Hmmmm, that is going to limit your choices. Any chance you can budget a change of wheels also ?
