JJBIRISH
Oct 25, 2013Explorer
Just thinking here…
Let’s see almost all never experience a tire blowout, or even know about the controversy, even though they are often overloaded driven to fast and not well maintained often abused…
Based solely on the fear caused by the few that have had blowouts, very many of them having been aired over and over on the internet forums along with the many stories that are reported by a friend of a friends, friend, that knows a guy, all proving how big and bad the problem really is… change is needed…
The choices of change are…
Buy a better tire and maybe 1 up it in load range or size…
To or three upsize and don’t worry about the tire builder…
Switch to a 15” LT tire with new rims and tires assuming there is room, normally requiring a size and load range update…
Preference is to go to an All Steel LT upgrade in 16”
Or to go from a P rated 205x15 on a 5” rim, to a LT235/85R16 load range G on a 6.5” rim… or from the current 5430 tire load limit that is on the 7000GVWR trailer, to a 15,000 tire load limit for that same 7000GVWR trailer…
I am way ahead of all of this… here is my new tires being balanced… the added advantage is they without the added expense they will be like a run flat under my trailer… no TPMS needed…
