Reddog1 wrote:
You got it on the photos.
As I recall, it was not required to change to non-OPD valves on horizontal tanks because the valve would not work properly. If your tank has been retrofitted with the OPD valve, that could be the issue.
I understand the new Horizontal tanks have the OPD valve, but it is designed differently than the first OPD valves used on vertical tanks.
I have no less than nineteen 5-gallon vertical tanks. Eleven are on equipment and eight are spare tanks. I have been using the OPD tanks since they first came out. None have ever had a sticking valve. I haven't used a horizontal tank since the OPD valves came out.
I'm thinking I pointed this out earlier.
"... He checked the number on the new valve and said he thinks it's the wrong one. He kept the tank and said he can fix the problem. ..."
