lcirelli's avatar
lcirelli
New LT tires on f150, what PSI
Hi, just bought new tires for my 2011 F150 max tow, had the p285/65 r80 and upgraded to the Michelin LTX M/S2 E rated tire same size. I used to run the p tires at 35 unloaded and 45 towing. When I checked the PSI after they installed the tires, they put in the same 35 as was on the door sticker. when I called Ford they said the same as the tire dealer, when I called Michelin, they said the same thing. Am I crazy, but shouldn't these tires be put at a much higher PSI. My trailer has a very heavy tongue weight. My rear axle came in weighing 3700lbs with my WDH on. What PSI should I put the tires at towing and not towing? I have read so many different forum answers, it seems no one has a good answer. When I called Ford I asked what PSI do they run on the F 150's that had the LT tires as standard equipment, and he couldn't answer me. If someone has an F150 that came standard with the LT tires, what does it say on your door sticker? I don't want to ruin these expensive new tires by running them too low.
