bobndot
Apr 14, 2017Explorer III
Most of the time max PSI is used on trailer tires because most trailers are towed near gross weight.
Sometimes trailers do not weigh close to the gross weight and your tires may wear out in the middle at max PSI. So, over time, check the wear of your tires and its ok to reduce the PSI by 5 lbs or so in order to have your tires wear correctly.
44,056 PostsLatest Activity: Nov 19, 2013
